Cummins12V98 wrote:
Right from B&W's web sight.
UNATTACHING TRAILER
Lower landing gear and block the trailer wheels. Raise the trailer until the tongue weight is removed from the truck. Then, unpin the Coupler handle and rotate to the open position to unlatch the jaws. If the jaws do not open, readjusting the landing gear may relieve pressure and allow them to open. Use the safety pin to lock the handle in the open position and when you are sure that the landing gear will support the trailer, move the truck forward to release the jaws from the kingpin. The jaws will always open when the pressure of the trailer is taken off the Coupler as the truck pulls away.
Wow , I lower the landing gear unlock the ball ,and raise the fifth wheel off the ball, and drive away. What was it someone said , easy peasy with the Andersen. No messing around trying to get the right load unloaded for it to release .
