texasjayco wrote:
Cummins12V98 wrote:
Learjet wrote:
Cummins12V98 wrote:
UNATTACHING TRAILER
...Use the safety pin to lock the handle in the open position and when you are sure that the landing gear will support the trailer, move the truck forward to release the jaws from the kingpin. The jaws will always open when the pressure of the trailer is taken off the Coupler as the truck pulls away.
yep, the way the cam is connected to the handle..I don't see how it wouldn't not release if the handle is pinned open. never, ever have I seen it not release when pinned open. If my truck rolls forward when I move the handle open...no need to pin....if the handle stays open...no need to pin...if the handle will not stay open...pin it...it is that easy.
I think all the "problems" are from not following the procedures :)
Right on!!!
Absolutely!!
That's what I love about the B&W...if the arm is closed, it's a solid coupling. If the arm is open, the jaws will release. You just have to pin it open sometimes.
Mark
That what I loved about my Reese Signature , if the arm is closed, its a solid coupling, if open the jaw will release, one difference I didn't have to pin the handle open. IMO thats asking for trouble , ask the guy that did that ,and dropped his fifth wheel on the bed of his truck. They should have designed it like the Reese Signature handle where you just have pull it open push it to the rear ,and it catches , but won't lock up when backed into.
