meleavingsoon
May 20, 2017Explorer
Thanks Old Biscuit...I found that same parts list sheet yesterday after Dometic and all the RV parts stores were closed so I couldn't call anyone to discuss the availability of the part. Looks like it is a revised parts list from the original literature that came with the trailer with a new part number.
As for the sprayer, you may have just fixed it by telling me that it is only pressurized when flushing the toilet :) ....I didn't realize that was the way it was suppose to function. I just assumed there was water pressure on the sprayer at all times.
I can flush the toilet and hold the sprayer handle down and I get water thru the sprayer just fine while the toilet is flushing. But at the same time the water is still spraying out from the vacuum breaker.
So, if I can just learn how to remove the vacuum breaker I was thinking I might try soaking it in some lime-away to see if it is just plugged up???.... Until I can get a new one ordered.
Thanks so much for the tips!
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
