MustangRacer_35
Sep 04, 2021Explorer
I had the same issue and solved it with Ace Hardware part number 40084. It's a shower flow control, just turn off your supply line after having no water pressure. Then turn on the flow control unit and attach the supply line to the flow control. Then press down on the pedal and turn the adjustment to desired flow. problem solved for about $10
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
