Coach-man
Nov 28, 2015Explorer
As stated, the problem could be either valves, or cables. I had a ckass C with similar problems, and I ewplaced the valve. To me, the problrm, is getting the valve correctly installed, from the factory that valve was a little off, which made it sticky, and it eventually fail. Taking the time to align it correctly and it was as smooth as silk. Ny $0.02 would be check the valve, you could have a similar situation.
About Fifth Wheel Group
