rockhillmanor
Nov 28, 2015Explorer III
Coach-man wrote:
As stated, the problem could be either valves, or cables. I had a ckass C with similar problems, and I ewplaced the valve. To me, the problrm, is getting the valve correctly installed, from the factory that valve was a little off, which made it sticky, and it eventually fail. Taking the time to align it correctly and it was as smooth as silk. Ny $0.02 would be check the valve, you could have a similar situation.
x2
I found once the handle starts giving you trouble pulling in or out the valves are in need of replacing OR there is something stuck in them.
The blades are 'very' then. A small piece of toilet paper, etc, stuck on where they slide up and down will cause problems. I always check that before replacing the valve blade.
Drain your tanks and get a toilet brush or any brush with a long handle and open the main cover and then open the valve blade and take the brush and run it around the opening to clear out any debris that might be stuck where the blade slides. This sometimes will clear up the hard to push in valve handles.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
