gman421's avatar
gman421
Propane Alarm
I recently bought a used 2007 NuWa HitchHiker 5th Wheel which the seller delivered to my house. The next day as I was getting familiar with it I smelled what I thought was holding tank odor, a little later that day the propane alarm sounded. I checked the tanks and found the valves closed but to be safe I removed the tanks from the trailer for a couple of days. About 3 days later I put the tanks back in and connected them but did not turn them on. A week went by with no more alarms sounding. I finally took the trailer for a test ride of about 3 miles at 1pm then parked it and unhooked my truck, at 4am the next morning the alarm began to sound and there was a slight odor in the trailer. I aired it out and have not had a problem for the last 2 days. I have changed the alarm at RV stores recommendation since it was 7 years old. I am baffled by this situation and am wondering if anyone has had a similar problem. Remember the valves on the tanks have not been turned on through any of this.
  • The alarm will also come on when the 12volt battery gets low. If it happens again, charge your battery and see if that resolves it.
  • The odor and alarm only came after the trailer was moved, when. I opened the toilet flush valve and did not detect an odor coming from the holding tank.
  • Holding tank fumes may cause the alarm to go off. Mine did that to. Check to see if your vents are blocked. There should be no odour in your unit.
