powertoolsgudie wrote:
Hi all,
I want to install a generator in my house as an emergency power supply. I have three options out there. These are solar generator, gas generator, and the propane generator. Among these choices, what do you think would be perfect for me? I need to keep running my essential electrical appliances like 2 fridges, 3 ceiling fans, a water heater, 6 indoor lights, and one porch or patio light.
You say you have propane available, so use that, pretty much end of thread.
As to size, depends on what everything will require that you list.
Many, many houses around me get by very comfortably with a 5,000 watt generator. Seems to be a rule of thumb - when in doubt, get a 5,000 watt generator.
We had a 3 day outage recently, and the Honda EU 3000 that we just got used from a friend worked awesome - powered frig, freezer, lights, and the window air conditioner for the main part of the house. With all that it was barely running above low idle. I was impressed. On top of that, it is an amazingly quiet generator - quieter than an EU2000 gen.
If you go gasoline generator, unless you really, really, really know that you will be able to consistently run the generator regularly to keep everything working, I highly recommend running the engine dry with storage fuel/non-ethanol fuel, then drain out all the fuel you can - store it "dry".
Let us know what you are planning on doing!
