abc40kids
Nov 22, 2018Explorer
Propane question
My fifth wheel has two tanks like most, if I put the knob in the middle and not right or left will it choose the full tank when the other goes empty?
MFL wrote:Chris Bryant wrote:
One caveat- the changeover works on pressure, if it is very cold, the regulator will draw from both cylinders.
Interesting...any rough idea, as to temp, when this will happen?
Jerry
Dick_B wrote:
Haven't found an easy/accurate way to determine the level of the propane in the tank BUT you can tell which tank is empty by tapping on it with a hammer or screwdriver. The empty tank will have a much higher pitch sound and, of course, be much heavier if you try to lift it.
Dick_B wrote:Consider the pair to be one 'tank'. When the regulator indicator is green you are over half full and generally good for 24 hours minimum. If the regulator indicates red you are below half capacity and just go fill the cylinder indicated by the lever. Move the lever to the other cylinder at some point in the fill process. You will never run out. Check the indicator more often during heavy use.
TXiceman wrote:Due to lower vaporization rate at low temperatures. Low being well below freezing. Generally I doubt you would be more than 5% into the reserve when the primary cylinder goes empty. Exception might be heavy use such as running a propane generator with a heavy load.Chris Bryant wrote:
And just how does this work? Never saw this in 35 year of RVing.
Ken
Ken
