Jhurk's avatar
Jhurk
Propane quick change
I want to install a quick change on my propane line so I can connect my BBQ.. I have removed the regulator on the BBQ so I want to install quick change on line from propane tank. Where have you folks installed it?
  • cmeade wrote:
    Don't mean to cause a big debate ... But I have a really good friend that owns a propane company help me connect my portable generator to my 5ver and he would not use any quick connects because "they will leak". I have regular wrench fittings and screw in plugs only. He made a 25 ft braided hose that he said can be used as a tow rope cuz it is that strong.
    Anything will leak eventually. If they were such a problem, then many of the RV manufacturers wouldn't be installing the QD drop as it is as it would be considered a liability (i.e. and explosive one). I'm not going to lose sleep over it.
  • my BBQ at home has been installed off our main tank for over 15 years sand has quick connector. the propane company inspects our stuff every 2 years and no leaks yet, I guess anything can leak eventually.
  • Don't mean to cause a big debate ... But I have a really good friend that owns a propane company help me connect my portable generator to my 5ver and he would not use any quick connects because "they will leak". I have regular wrench fittings and screw in plugs only. He made a 25 ft braided hose that he said can be used as a tow rope cuz it is that strong.
  • Fortunately I have a tee connection where the water heater is. I tee'd off that. Only need a 6' hose. I went to the local propane dealer and had them fab up the hose and quick connects. It was relatively cheap.
  • Great thread! Now I know how to set my Q grill up to use my auxillary quick connect. This forum is so informative.
  • the middle slide on mine contains the stove, I did t off the pipe there and bought a 15' quick connect hose kit at the "depot of home". this way I had plenty of room to move the grill and keep it out from under the awning.
  • If your fifth wheel is typical, in that there is a separate 30# tank on each side, then if you trace the lines they probably come together at a manifold. Many have additional ports that are just blocked off. From here you could plumb an additional line with a QD.
    I've already done my grill conversion, removing the regulator, and installing the QD male end to hook the hose to. I was able to order a 25' gas line from Amazon here, and add the QD fittings to both ends. I also ordered one of these so that I could still connect a standard 20-30# tank if I do any tailgating.
    Here is a pretty good DYI link with photo's and part #'s that I found helpful: http://www.forestriverforums.com/forums/f68/kchinths-apex-288bhs-mods-102353.html#post1121560
    Good luck.
  • rhagfo's avatar
    rhagfo
    Explorer III
    That is a preference question.
    you should insert the quick disconnect where you would like to use the grill most of the time. If I remember correctly at out house the hose is about 10' to 12' long, in my case I would put it behind the axles.
  • I was able to place a tee in a line to the heater & extend it to the side of the trailer with a quick disconnect.
