GASMAN6674
Sep 21, 2020Explorer
The RegO 7525 series is a twin stage regulator. the change over head is the first stage (tank to 10psi) and the second regulator is the low pressure (10 psi to 11"wc) The unit carries a 10 year warranty. PS be aware the tanks shown in the picture are no longer "legal" all DOT bottle up to 40# require a OPD valve and all OPD valve have both internal POL and external QCC connections So you can continue to use POL pigtails thou I would recommend excess flow style connections. Your Unit- Your Loss
About Fifth Wheel Group
