Scott_85's avatar
Scott_85
Propane strap
I really hate the metal strap that secures the propane bottles, anybody replace theirs with something else? I was thinking about a cam buckle strap.
  • C Schomer wrote:
    My bottles stand up and they have a crossbar and huge wing nut that pushes the crossbar down on the tank necks to keep them in place. Gravity sucks... The crossbar always gets in the way when changing tanks. I put a collar on the center rod and drilled A cross hole for a drive pin and put a spring on top of the collar that pushes the crossbar up when I loosen the wing nut so the crossbar always goes up and stays out of the way. Craig
    Brilliant! :-)
    Lyle
  • My bottles stand up and they have a crossbar and huge wing nut that pushes the crossbar down on the tank necks to keep them in place. Gravity sucks... The crossbar always gets in the way when changing tanks. I put a collar on the center rod and drilled A cross hole for a drive pin and put a spring on top of the collar that pushes the crossbar up when I loosen the wing nut so the crossbar always goes up and stays out of the way. Craig
  • I like it. Open it and it stays there. You don't have to fish around for it when the tank is replaced. My 2 cents
