rhagfo
Jan 10, 2014Explorer III
Ka Ron wrote:
This does not sound like a propane issue, it sounds like a furnace issue.
Probably a sail switch??
GaHighPockets wrote:
9) I suspected low gas pressure so I turned furnace back on, went out side and put hand over the fresh air intake for the furnace, it would light right up and make heat as long as I kept intake mostly obstructed.
I believe it to also be a propane supply issue, if chocking off the air supply makes it work, most likely not enough propane for combustion.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 14, 2026
