GaHighPockets
Jan 10, 2014Explorer
I think if it were a regulator problem, the red/green indicator that tells you that you have tank pressure would be green. As the regulator is down stream of the indicator I suspect it to be a tank pressure issue as I changed the pigtails (which have a excess flow mechanism and a fusible link) It is also possible that the tank has too much pressure ( had the tanks filled early this week when the previous nights temp was around 5 degrees) thus every time I crack the valve it is triggering the excess flow valve in the pig tail. When I go home for the weekend I am going to make me up a pressure gauge to check.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 14, 2026
