NC_Hauler
Jan 10, 2014Explorer
I have two 40# propane tanks in my 5er....My furnace wouldn't stay lit with tank on the drivers side.....but would run with the curbside tank.....With the drivers side tank, I could turn on and run my stove, my gas water heater would run, (though I run it mostly on electric, I checked to see what would happen)...BUT, the stove wouldn't STAY lit.....The drivers side of the 5er where propane tank is has a regulator, as does the curb side....I changed out the regulator on the drivers side and now the furnace will work on either propane tank....
It was mentioned earlier and no one made a comment on it, but I'm here to tell you that it "could" be the regulator as mentioned by newman fulltimer, because it was the regulator in "MY" case.
On edit..I camped over Thanksgiving when temps were zero with a windchill below zero and never had an issue with either tank....
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 14, 2026
