Me Again wrote:
The weed burner has the old style male end with no excess flow valve. It works fine on old style tanks, hard to get flow on OPD tanks.
On edit!
Found this:
New OPD style valves have several safety features built in. The least frustrating is the excess flow check valve on the tank side of the connection which is set high enough that it almost never matters. That said there is another excess flow valve in the QCC connection (the big plastic hand wheel that fits the outside threads of an OPD valve) which is color coded. Black ones are set to 55k btus, green to 200k and red to 400k. If either of these is closing you will hear it click. Just close the valve, wait a minute and reopen very slowly. If you think it’s stuck closed just bang the tank on the ground a few times then try opening it again.
Chris
Got a link to this OPD valve that has an Excess Flow Device?
YES....the ACME NUTS are color coded based on flow.
GREEN is used on RV pigtail hoses based on LP Regulator flow capacities.
