- agesilausExplorer III
I don't have a dog in this fight, but I can't see why anybody would advise somebody to avoid a business because they want to follow SAFETY REGULATIONS enacted to protect you and the public?
You are correct, I should not have posted that. But it's not like they seize the tanks if they are out of date, they just send you on your way. Free to go to the next propane fill place. So someone determined to avoid the inspection can do so. - JRscoobyExplorer II
agesilaus wrote:
RAS43 wrote:
My 2 30# tanks are 16 years old and visually look good. No one has even looked at the date and questioned me and still fills them. I will continue having them filled until someone says NO.
I have a small 1 gallon tank that is 20+ years old and was told last year to get it checked before filling it again. I have a new 2 gallon tank filled and ready when the old one is empty. I se these with my grill for camping.
Avoid Tractor Supply then, they seem to have a company policy demanding that the date be checked. I've filled tanks at TS at several spots across the country and they all did check.
I don't have a dog in this fight, but I can't see why anybody would advise somebody to avoid a business because they want to follow SAFETY REGULATIONS enacted to protect you and the public? - agesilausExplorer III
Avoid Tractor Supply then, they seem to have a company policy demanding that the date be checked. I've filled tanks at TS at several spots across the country and they all did check. - agesilausExplorer III
MarkTwain wrote:
ilvtravln wrote:
Hi, My propane tanks are 10 years old, do I leave them as is, replace them, recertify them or what, not sure, not having any problems with them, where we go camping often they never check the date on them as they refill them, any input would be appreciated. Thanks
It depends on the price to recertify the tanks or the cost of a new one. I just take my tanks in for an exchange but I choose a tank that is only a few years older. You might be RVing in a location where they will not fill your tank if out of date. It could be a roll of the dice:)
I have never seen an exchange program for any tanks but 20#cylinders. And yes for 20# I just exchange it. My 30# cylinders got recertified. I see a 30# cylinder is $65 on Amazon, I'd expect recert price to be more like $10. - ApprovedAnonymousMy 2 30# tanks are 16 years old and visually look good. No one has even looked at the date and questioned me and still fills them. I will continue having them filled until someone says NO.
I have a small 1 gallon tank that is 20+ years old and was told last year to get it checked before filling it again. I have a new 2 gallon tank filled and ready when the old one is empty. I se these with my grill for camping. - Old-BiscuitExplorer IIIJust for clarification:
LP TANKS
ASME jurisdiction under NFPA ---- NO Recertification required
Tanks used in Motorhomes
LP Cylinders
DOT Jurisdiction ----Portable and require Recertification
Cylinders use on TC, TT, FW ---trailers - MarkTwainExplorer
It depends on the price to recertify the tanks or the cost of a new one. I just take my tanks in for an exchange but I choose a tank that is only a few years older. You might be RVing in a location where they will not fill your tank if out of date. It could be a roll of the dice:) - gboppExplorer
agesilaus wrote:
Where I worked we had gas cylinders dating back to WWI, yes one. Re-certified every 10 years and in fine shape.
I wonder if the tanks built today will last that long :@ - agesilausExplorer IIICheck the local propane vendors, I don't mean the cylinder swappers. One of them will do certifications and such. We got our tanks re-certified and since we got the tanks filled they didn't charge us for the service. No matter what it's cheaper than a new tanks.
Where I worked we had gas cylinders dating back to WWI, yes one. Re-certified every 10 years and in fine shape. - If you can get an easy and cheep re-certification that is fine. I just bought new 30# cylinders from Costco.com to be done with it.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
