I am still wayne_tw wrote:
watch this:
http://www.youtube.com/watch?v=4OIhFwwPq4M
That is actually really misleading - Rarely are trailers equipped with 4 tanks, and that regulator is designed for two. By combining both regulators onto a common line, it truly does create a backflow issue when removing both tanks on one side because they aren't designed for that. If he removed the one non-selected tank from both sides he would be fine.
I travel everywhere with the LP on. The tank valves have a high flow and overfill shutdown, the pigtails have a ball check that closes on high flow as well as a thermal shrink section that closes off the flow in a fire.
Just no point in sweating the small stuff - enjoy your rig to its fullest potential as it was designed for.
In 1998, a modified Type one cylinder connection was introduced to RV's. The main modification was to increase the flow rate allowed through the pigtail to meet the RV's typically higher BTU demand, but additionally there were two new safety features incorporated. The first safety feature deals with fires at the connection to the tank. The connection nut contains a thermoplastic sleeve that, when heated to between 240 - 300 degrees F, will fail in such a way as to back the pigtail connection out of the cylinder valve, causing cylinder pressure to close the cylinder check valve, interrupting the flow of gas. The RV connection nut will be green as seen in the photo on the right.
The second new safety feature is called a “flow-limiting device,” and its purpose is to restrict the flow of escaping gas if there is an excessive leak in the RV’s gas system. It’s this second flow-limiting device feature and how it works that seems to cause the most problems among campers. Almost every time the cylinder valve is opened, a small ball in the center of the brass nipple (inside the green nut) is pushed forward into a brass seat. This seat doesn’t totally shut off the gas. By design, it allows a small amount of gas (by-pass flow) to go into the RV’s gas system. If everything in the gas system is closed and in the “off” position and if there are no leaks, the by-pass flow builds up a back pressure that equalizes the pressure in the system with the cylinder pressure and with the help of a small spring, pushes the ball back off the seat and allows unrestricted flow through the system. All this happens in about five seconds and the owner doesn’t even know it’s happening. Appliances light, furnaces and water heaters run, and every-thing is normal.
