RudiH wrote:
I recently bought a new 5th wheel (Crossroads Cruiser Aire - 31.5') and a new Ford 250 Super Duty truck. The truck bed is higher than that of my last truck, and I am concerned about being able to level the rig without doing some modification to the pin box. I have not been able to hitch up yet because I left for Florida for 3 months for the winter right after the purchase. Is anyone towing a 5th wheel with the truck mentioned above? Did you have to make any modifications in order to tow properly?
I would like to be prepared for what I need to do when I return home.
Thank you in advance for your time and advice!
Well did some research and based on model length it seems you have a CR27MK. Nice looking floor plan, question did you get the CRUISER HP UPGRADES? This would include 16" wheels. That is a nicely sized 5er for your TV.
As mentioned you have two numbers you need to worry about:
#1 5er overhang to bed rail clearance, this should be 6" minimum.
#2 How level will the 5er tow, or how nose high will it be.
You can calculate both, for the bed rail clearance two measurements.
#1 lay a straight edge across the bed rails at the hitch, measure the distance from the top surface of the hitch head, with it level to the bottom of the straight edge call this measurement1. Now measure the distance from the bottom surface of the 5er overhang, to the bottom of the pin box surface (the surface that the pin is on) call this measurement2. Now subtract measurment1 from measurment2 this will be the bed rail clearance.
#2 Best with 5er and TV able to hitch. If you have both at the same location, find a level spot big enough for both TV and 5er to sit on the same level plane. First hooked up. Measure at hitch pin location to top of bed rail, call this measurment-1. Now disconnect the 5er pull TV clear of the 5er and lower until it is level. Now measure from the ground to the bottom of the front overhang call this Measurment-2.
Now math time Measurment22-(Measurment11+6)= distance the 5er needs to be raised at the axles to tow level. The +6 added to Measurment11 is the distance you wish to clear the bed rails by.
