Harbor Freight makes big rubber chocks that are the same as the more expensive ones.
I took a small level and glued it to a small magnet I had and keep that in the side compartment where the propane is and stuck to the frame. After I unhitch and pull the truck away I open the compartment and turn the whole magnet and level it until its level, or just about - thats where I know I need to be when raising the front legs to hook back up. Its cheap and simple and takes the guess work out of it.
Then I just go about and do my normal front to back routine etc... Also I use chocks as everyone else has mentioned.
