rsgs
Jan 15, 2019Explorer
I don't know of a timed procedure for testing brakes. I always accelerate to about 25 and hit the manual slider without using the vehicle pedal. If I feel resistance and it slows my progress, I feel it's good (per the users manual). My average setting is 6. I do switch settings between my 32' and my 28' due to the weight difference. This has worked for me for 16 years. As far as working poorly when you first pull out, I would ask how long does the coach sit before trips? Could be a thin layer of rust on the surface of the drums that will grind off after repeated stops. Same if you have rotors.
About Fifth Wheel Group
