Likes_to_tow
Jan 15, 2019Nomad
I pull my wheels and check brakes for any grease on the pads each Spring, replace the seals and hand pack bearings. There have been no bad experience with drum brakes for me so far. To test the brakes I just roll along at about 25 and pull the hand actuator. If I feel the brakes come into play I assume everything is ok. When I'm driving on the Interstate or any roads where my speed is constantly beyond about 55 then I use the top setting on my controller. If I'm in heavy traffic I use less setting.
After you pull for a while you will get a feel for your brakes. You can tell if they are working like they should. I don't believe a timed duration on stopping tells you much other than you know they are working properly. I like changing my brake controller setting for different conditions. Just my opinion and style I suppose.
About Fifth Wheel Group
