dapperdan
Apr 27, 2017Explorer
John & Angela wrote:
Depends on your RV and how many batteries you have. Not to mention solar. If you have 4 X 6 volt batteries and a 300 or 400 watts of solar you can pretty much leave your fridge on indefinitely when in storage. Modern residential fridges don't use a lot of power. Ours uses less than an amp and a half and that is only when its cycled on which is about a third of the time. Dry camping you should have a little more solar for the rest of the coach. Solar is cheap now a days. We have no problem dry camping but we still run our generator when we use our microwave or toaster or coffee maker for any amount of time. Those are bigger loads. In bad weather our biggest loads are the TV's and computer which get a lot of use if we are couped up inside.
Cheers.
We have the same set up as Rusty, I mounted 3 100 watt panels on our roof. They do a great job of running our residential fridge while off grid. I only have 2 6 volts batteries at this time though and if we get too many cloudy days here in the midwest (Wisconsin) I can run out of power. I'm still on the fence about adding 2 more 6 volts to the trailer. If we lived in the southwest I believe we'd be all set.
We've had propane powered fridges before, this is our first residential fridge but for us, the way we travel the residential is a no brainer, love how well it cools and how fast it can cool down if we shut it down for extended periods and it's larger size.
Dan
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
