riltri wrote:
I'm moving from a LB GM to a Ford with 6.75' bed. The truck does not have factory installed puck system. I want to stick with a new B&W slider hitch (I don't think that a slider is required with my 2015 5th wheel's rounded nose, but want the option of using it). Will be pulling 12,300lbs.
- Which puck system should I have the dealer install?
- Can the Patriot slider easily handle 12.2k lbs? I know it is rated for 18k but has anyone heard of issues with it?
Thanks
Do you know you can install the pucks yourself just buy the parts.That what I did.
