Me_Again
Mar 23, 2016Explorer III
Pull tests
In another thread there was a lot of talk about pull tests. In 1997 we got our first 5th wheel and a Hijacker 16k Ultra sliding bar hitch. We never did pull tests. The hitch in 2001 moved two a se...
In 1997 we got our first 5th wheel and a Hijacker 16k Ultra sliding bar hitch. We never did pull tests. The hitch in 2001 moved two a second RAM truck, and 2004 we upgraded to a larger 5th wheel. If the handle and sliding bar that the handle was directly attached to slide in then it was correctly hitched. We ran with a padlock in place of the lock pin 99 percent of the time.
In September we got a 2015 RAM and decided on a manual slider from B&W(RVK3270).
The B&W lock handle is connected to a dual cam that is between the front extensions of the king pin jaws. So if the handle is in the locked position, pinned or not the jaws will not open when backing into the hitch, as the dual cams are at a right angle to the jaw extensions.
To couple up the handle has to be swung forward. When you back into in correctly the king pin slides in between the jaws and then pushs them closed and the spring loaded handle swings to the lock position with the dual cam ends pointing left and right blocking the jaws from openning again. At this point one pins or padlocks the arm in the locked position.
So following these steps and installing the padlock, I feel the same as I did with the Hijacker, in that there is no reason to do a pull test.
However if a person feels comfortable doing a pull test, then by all means go ahead and complete that step.
Chris
