IF truck/trailer are properly matched if doesn't matter
Can be a 1/4 ton truck or a 1 ton dually and everything in between.
Overloaded is overloaded.
Within capabilities/ratings then it doesn't much matter.
Personal preference plays into it also.
Some folks are comfortable with SRW and others are MORE comfortable with DRW
Understand tow vehicles REAL ratings and match them with trailers REAL weights all good to go
I have a 3500 SRW and tow a 13,873# (actual scaled weight) 5th wheel.
First 7 yrs was FT all over the USA.
NEVER had a 'white knuckle' moment or a second thought of 'should have had a DRW' cause truck/trailer were 'matched'
Have had DRWs in past and for the weights being towed they were the right tool
Right tool for the job..........don't need a sledge hammer when a tack hammer is right tool. Vice versa....tack hammer is NOT what you want when driving spikes.
