rhagfo
Jun 25, 2015Explorer III
garycq wrote:
I have a 30' 5th wheel and pull it with my Dodge diesel truck. The rear end gearing is 4:10 and the trans is an automatic which has been rebuilt for heavy towing. I was told recently by an experienced RVer that I should never tow my 5'ver in over drive. I usually tow at 55mph or less and I do use over drive on level highways. He told me he has torn up a couple of trans by using overdrive. I was curious about other peoples experience about towing with an automatic. When going up any grade the over drive goes off.
Thanks
Gary
I can't speak for a auto, but with what you have I see no reason for not using OD, on flat land. I have the 5 speed manual. That said even with 3.55 it doesn't strain pulling 11,000# at 65+ on the flats.
Your issue would be too much power for the build on the Tranny.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
