valhalla360
Apr 25, 2022Navigator
JIMNLIN wrote:
Assuming it has a % safety factor isn't wise.
Just like its not wise assuming our tires with a 3500 lb load/80 psi rating has a safety factor and can support more psi and load.
Trailer hitches has a load and draw capacity.
I sure wouldn't exceed the hitch mfg 20k draw capacity....nor tell anyone its safe to do so long term.
Using the safety factor to justify pulling a 25k trailer with a 20k hitch...yeah that's foolish as you don't know exactly what safety factor was used and it's possible you might exceed it.
Pulling a 20k trailer with a 20k hitch is perfectly fine and yes, I can guarantee the structural engineers built in a safety factor.
If you are going to load up a 20k GVWR trailer to 25k, you probably don't care if you are exceeding the hitch as you are likely overweight on the axles, tires and other parts.
No different from a tire rated for 4000lb and putting 4000lb on it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
