timelinex
Apr 27, 2022Explorer
Cummins12V98 wrote:timelinex wrote:Cummins12V98 wrote:
So you are saying the hitch mentioned should be used with toy haulers so the pin is less?
Tandem axle 5ers have 20-25% pin weight. On the higher side especially if fulltiming.
I'm sorry, I'm not sure I understand what you are saying. So I will restate my point.
My post had nothing to do with using a specific hitch. I am saying that the rule of thumb you are using (20%-25%) is not a god given fact, but just a rule of thumb that applies to maybe most 5er's. However, that there are many 5er layouts that produce 15%-20% hitch weights, by design and layout.
For Example: If you look up factory numbers for the Grand Design 381m (NOT THE 381MS) you will find they are much less than 20%. Then if you look up peoples posts on what their hitch weights are for their FULLY LOADED 281m trailer weights... You will quickly find almost no one is breaking 20%. Most are at 16%-18%. It's not because they all decided to irresponsibly swing the rear end of their trailer down the freeway.
The problem is what i saw was you were posting unloaded factory weights. Most all weight added to a standard 5er goes to the pin. Toyhaulers are a different animal.
My original point is it is unrealistic to have a 28k hitch with only 5k pin unless those numbers are not correct???
OK, sorry I misunderstood you. You were commenting that even though it's possible to have a 5k pin with 28k trailer, it would be odd to make a hitch with those limits since you would only be able to come close to that tow rating with that little pin weight in a minority of applications. Effectively making it a 20k hitch for most people.
I agree that this is odd, but seems fairly consistent to how truck manufacturers do it. Sell based on tow capacity and smuggle in the piss poor payload rating under covers.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
