cummins2014
Mar 18, 2014Explorer
rrwantr wrote:N-Trouble wrote:
Let's see, auto slide for less money, or manual slider for more money?
Where do you see the auto slide for less money?
The lowest I've been quoted for the 16k autoslide with superrails and plate is $2500 installed. The BW companion slider and turnover base installed I can get for $1875.
I have already done your homework for you, get the picture frame from RedTrailers.com $326.54, and either a 15K or if that is not enough weight rating go the 18K both are the superglide ISR series in other words they fit conventional rails or the picture frame that you are already setup for. The price at Tweety's is $837.80 for the 15K ,and $1111.11 for the 18K both are free shipping. you are going to be total either $1437.65 for the 18K setup or $1164.34 for the 15K there will be no installation fee there is nothing really to install, you can do it all
You DO NOT need the super rail kit with your truck, just the picture frame ,and ISR series Superglide. I did forget to mention the capture plate for around $100 depending on what hitch is on your fifth wheel
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
