IdaD wrote:
donn0128 wrote:
Not enough truck!
Fords are heavy to begin with, and depending on year you could have a honest load carrying capacity as low as 1500 pounds. Dry pin weight is really a misleading number. You will NEVER tow a dry trailer. You may not ever see it, but lacking real world numbers take a worst case. Trailers GVWR is what you want to look at. 20% of that is your pin weight.
It may or may not be enough truck, depending on age. On the newer models, an F250 is the same thing as a SRW F350 except for an overload spring and an axle block (in some cases as I think these are optional on the F250). Even if those aren't present they can be added and you've got exactly the same truck aside from the payload sticker and the decal on the fender.
Again this depends on year. I think in some of the older models the 3/4 ton series was actually somewhat lighter built in terms of axles used and etc.
It really depends on the model year, crewcab or not, and diesel engine will take away about 700 pounds of cargo rating compared to the V10. 4X4 option is also about 400 pounds more than the 2WD.
In 2004 and earlier, the GVWR was only 8,800 pounds and a crewcab diesel can only carry about 900 pounds! The 2005 went to a 10,000 GVWR and can carry about 3,000 pounds, and that is plenty for most smaller fifth wheels.
I would check the curb weight, and post your GVWR so that you will not get a lot of replys that your truck is to light. You can find the GVWR and axle weight ratings on the drivers side door sticker.
If you have a 2005 and later F-250, you have plenty of truck. Earlier ones are not such a heavy hauler. ..
Good luck,
Fred.
