JIMNLIN
Mar 20, 2018Explorer III
Over 30 members have reported issues with the ST 8008.
When the BFG Commercials started having issues, Michelin stepped up and gave the Ribs and Michelin LT as replacements with warranties.
Another paste and copy from the same era when FastEagle was on his anti Michelin XPS Rib debacle.; he too was using false information on what Michelin actually says on the subject
** (paste and copy)
I sent an email to Michelin for a response regarding using Michelin XPS ribs on my 5th wheel. Here is the question and their response:
Thank you for your email. We welcome the opportunity to serve you.
Due to recent high email volume and some technical issues that we have experienced, please accept our apology for the delay in this response. Your interest in Michelin is certainly appreciated.
In regards to the email you sent stating:
I have a 2006 Montana 5th wheel Trailer that has two 6,000 lb Dexter axles and 4 deluxe aluminum Rims each rated at 3,042 lbs. I would like to install your Michelin XPS® Rib™ LT235/85 R16/E's on this 5th wheel. Will the tires be fully waranteed in this application?
Answer..------------------------------------------------------------
We appreciate your request for information regarding the Michelin XPS Rib. The XPS Rib, size LT235/85R16/E, part number 13080 would be a good fitment for your 5th wheel. The tire carries 3042Lbs at 80-psi max pressure. For best pressure recommendation, run at maximum pressure until you can weigh your axles either call or reply to this email for a pressure recommendation.
It is a good application, so there are no warranty issues. Your tires are covered under applicable warranty.
We appreciate your business and thank you for choosing Michelin.
It is our goal to ensure that your issue has been resolved or your question answered to your satisfaction. If we can assist you further, please respond to this email or call us at 1-800-642-4354 (toll free) between 8:00AM and 8:00PM Eastern Time Monday through Friday or between 8:30AM and 4:30PM Eastern Time on Saturday.
Sincerely,
Diana
Consumer Care Department
Certified Michelin Product Expert**
So...your dealer says Michelin won't honor their XPS Rib warranty on a trailer and emails from Michelin says they will....agree with others , I sure would be looking for a experienced tire dealer that knows something.
** (paste and copy)
Sincerely,
Diana
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
