KD4UPL
Jan 13, 2016Explorer II
2oldman wrote:
I don't know how a solar panel is going to surge enough to burn up a wire.
Depends on the rating of the solar panel and the size of the wire.
Either way, we're not talking about only 1 solar panel. If we were then no fuse would be needed in line with it. We're talking about 4 solar panels in parallel. If one shorts then the other 3 will try to send their current thru it. Thus, we need fuses.
Also, code requires it if you apply NEC to RVs.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
