ford_coupe
Jun 12, 2014Explorer
quadra-step
Has anyone installed the quadra-step on their 5'er? If so how hard was it & was it worth it? thanks for any answers. Have a great day
tartan camper wrote:
Traveler, I've located a welder and plan to get the stair unit to him so he can cut the rod down and weld a washer to hold it in position (I assume that's what you did also). Looks like the installation will be fairly easy. I also have a floor jack and can do the same installation steps as Old Duck. I think DW will be very pleased! Thanks, everyone.
That rod is going to be a problem - it sticks out 3/4 inches on both sides of the unit. I can either have the rod cut and have a washer welded on to hold it or cut the support hanger so the rod doesn't contact it. The need for supports makes sense as it hangs out farther than the three step unit does. I'll follow your advice on that as well. Thanks Traveler!
