That rod is going to be a problem - it sticks out 3/4 inches on both sides of the unit. I can either have the rod cut and have a washer welded on to hold it or cut the support hanger so the rod doesn't contact it. The need for supports makes sense as it hangs out farther than the three step unit does. I'll follow your advice on that as well. Thanks Traveler!
