DutchmenSport
Oct 18, 2017Explorer
Any insulation is better than none. If it were me, I just get a roll of fiberglass type insulation (it comes with different R-ratings)... More "R", the fuller and thicker the insulation. But, nothing says you can't take a lesser "R" rated for the thinner spots, and just add layers in the fatter spots.
Actually, anything on this page will work just fine. It all has to be cut and fitted anyway. Click here.
And this will work equally as well. Click here. It also has to be cut and fitted. It's really your choice.
Although, the loose, "blown insulation" would not very well in a camper wall. It would all shake to the bottom between the studs and compact. Insulation value would be zero then.
About Fifth Wheel Group
