fulltime5er wrote:
NC Hauler wrote:
fulltime5er wrote:
On pin weight, I can only go by manufacturer's info, since I haven't anything else to go on yet.
Speaking more from experience than anything else, and a 5er that weighs in at 20,000#, if that's the one you'll go with, COULD have a pin weight of up to 4,000#, unless it's a VERY light unit...Is it two axle or three axle?
Again, I'd still want to know some of my trucks ratings, if you go with a 20,000# 5er, that is a pretty heavy 5er, even for a 1 ton dually.....
2 axle on all of them. Most of the ones we are serious about are in the 16-17,000 gvwr range.
Ford says the GCVWR on my rig is 30,000, and maximum 5th wheel towing is 22,200. I THOUGHT that would be enough truck. I wanted the dually for extra confidence in towing that much weight. With the fivers we are looking at, we should be under the maximums, which is what I want.
