fulltime5er wrote:
AS the OP, I am not upset with any discussion or question about what my TV is. I am here to learn, and really only looked up the maximum tow rating and GCWR AFTER being asked about it, so thanks for the question. Now I know for sure that the TV will handle the load, with room to spare.
Thanks to ALL for the responses to my question.
Uhh, gosh new guy welcome to the forum. Some folks get carried away with the weights thing.
Too bad the weight police showed up first with their nonsense of you have to have a one ton DRW .... errr now I guess it a F450/4500 truck. :R Pretty typical.
Anyhow as you found out you don't need a F450/4500 truck to tow the trailers of your dreams. With payloads for your truck from 5500 lbs up to 7000 lbs and 13000 GVWR with those big 9650 RAWR you sure don't need a bigger truck.
Now to your question.
A 37' to 40" trailer are long trailers. IMO a big issue is will it go in campgrounds you like or may use. Only you can answer what your needs may be. I would get the trailer you like best. If you find a older campground you like or may be staying a nite call ahead and see if the 37-40 footer will fit.
