rollexx
Jan 20, 2020Explorer
You might not have to remove the whole underbelly material if it’s what I have under mine. Mine is a corrugated plastic material. When I had a broken remote dump valve line repaired they just cut a flap in the underbelly and then taped it back up. No problem.
You would just have to cut a bigger flap to expose the tank. Shouldn’t be that difficult to remove tank. Hooking up new sewer line would be easy. Only issue would be the hole and if new toilet would match up. If not, perhaps one of those old fashion wall mounted tanks if wall could support it.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
