mpfireman
Sep 15, 2013Explorer
I thought that ALL pumps came with a way that you could winterize your unit without adding anything to it. There should be a shut off valve located at the base of this open ended tube. This valve is closed during everyday use, and only opened when you want to winterize your RV. Winterizing your unit should take less than 30 minutes, but it will probably take you longer the first time as you are not familiar with all of the drain valves.
In the picture, i can see a plastic handle that opens and closes one of your water lines. If you know anyone who has an RV, they could help you locate and ID all of your lines.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
