45Ricochet
Jul 16, 2013Explorer
Beaker wrote:--------------------------------------------------------------------------------
riggsp wrote:
I was taught to adjust drum brakes until the wheel won't spin (this centers both shoes in the drum)then back off a few clicks until it just slightly drags...back off all of them the same number of clicks...never had any problems doing it that way.
Bingo! You get the award for first correct answer.
Now if someone knows which way to tighten or loosen would be nice.
:B
Good one, I had to write it down and put it in the tool box for reference. And it's way the heck out back now so I don't know, but a few turns will tell you.
Thanks for all the responses guys, I must be setting them to tight as a subliminal message to wear them out faster and thus the disk brake upgrade. Darn Jacobs brake, I'm still over 50% on the linings of the RV with 30K miles. At this rate I'll need a new RV before the brakes need replacing.
Thanks again
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
