Bumpyroad
Feb 25, 2017Explorer
a factory fix would cost more than the rv is worth. fix the leak first. if the rear wall is wooden framed and you can find the "studs" you could fasten down some laminate. but it will have zero resale but if you can get enough use out of it and it is basically free????
but Run, Forrest run.
is that a slide out that has the lower corner not pulled in tight?
bumpy
bumpy
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
