WE-C-USA
Apr 12, 2020Explorer
Once the trailer is raised to/& disconnected, the auto reconnect will not work if you use anything but the Auto Level. So if you lower/raise the front after disconnecting, you have to use the manual mode to get the height back to hook back up.
Once the truck is pulled away, hit Auto Level. Than it will return using Auto Reconnect.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
