laknox
Apr 14, 2020Nomad
Super_Dave wrote:laknox wrote:
Not sure which LCI system I have, but I tried using the hitch height feature on 2 occasions and neither time it worked properly; no way to rehitch without manually adjusting the legs. So, I just hitch manually. (Shrug) It levels properly and retracts with the push of a button. All I need it to do.
Lyle
When you have all jacks down how are you raising them before manually lifting the front?
Here's my basic process to hitch:
FW is level on all 4 jacks.
1) fully retract rear jacks via the menu
2) manually extend/retract front jacks to proper height to hitch
3) back into the hitch, latch hitch, use the menu to retract front jacks
Reverse to unhitch. The only other thing I do is to slightly raise the front jacks before tightening the JT Strongarms, then drop back down to put some compression on them. Maybe 1/4", or so.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
