bucky
Jul 08, 2023Explorer II
The advantage to hydraulic slides is that you can deploy/retract all at the same time or one.
Open the outer door to the system. Likely you will see a label identifying which cylinder controls which slide. My former fiver had a thumbwheel on each valve. All the valves will be open for all slide operation, but you can turn the thumbwheel for each slide to disable one slide at a time.
Only allow the slides you want to function to hang over a curb but keep the lot side in.
About Fifth Wheel Group
19,041 PostsLatest Activity: Aug 21, 2017
