GrumpyandGrandm
Sep 07, 2014Explorer
Me Again wrote:GrumpyandGrandma wrote:Me Again wrote:GrumpyandGrandma wrote:
Most RV tire issues are not due to where the tire came from, but from improper loading, under inflation and speed. 99% of all ST tires (US made included) are speed rated at 65. As to using LT on a tandem axle set-up, it is not recommended due to the side wall flex in hard turns. LT's have been known to pop off the rim in a hard turn due to the stiffer sidewall. The other big issue with ST tires is how long the unit has sat on a dealers lot (usually gravel) without moving before it is sold.
What a crock! ST tires fail at a high rate because they are a bottom tier cheaply made product, that we designed for utility trailers and local service. Some brainyact decided that one could see America with them on large heavy tall trailers.
Chris
You have your oppinon which if fine, but all you have to do is "research the facts". I camp with two very large clubs that are composed of 95% trailers and fw and the members do not have a large tire failure rate. Those that do are usually at the 5 to 6 year age range.
Here is some of the info
Trailers will be more stable and pull better on tires designed specifically for trailer use. Since Special Trailer (ST) tires are constructed with heavier duty materials, they are tougher than typical passenger vehicle tires. This is a plus because trailer suspension systems are generally stiffer and less sophisticated than automotive suspension systems.
Special Trailer (ST) Tire Speed Ratings
Industry standards dictate tires with the ST designation are speed rated to 65 MPH (104 km/h) under normal inflation and load conditions.
However Goodyear Marathon and Power King Towmax STR tires featuring the ST size designation may be used at speeds between 66 and 75 mph (106 and 121 km/h) by increasing their cold inflation pressure by 10 psi (69 kPa) above the recommended pressure for the rated maximum load.
Do not exceed the wheel’s maximum rated pressure. If the maximum pressure for the wheel prohibits the increase of air pressure, then maximum speed must be restricted to 65 mph (104 km/h).
The cold inflation pressure must not exceed 10 psi (69 kPa) beyond the inflation specified for the maximum load of the tire.
Increasing the inflation pressure by 10 psi (69 kPa) does not provide any additional load carrying capacity.
Marketing BS taken straight from a marketing web site. If all the things you posted were true ST would start at 300 bucks. Manufacturers most like pay less than 50 bucks for a ST235/80E16E.
OK you know more than EVERYBODY, including Mark Polk
http://rvingwithmarkpolk.com/2012/11/08/trailer-towing-st-tires-vs-lt-tires/
Here's some of what he says after he mentions both defective ST and LT tires
ST Tire Blowouts: Pay ATTENTION to the second sentence.....
When I talk about ST tire blowouts I am not referring to what we just discussed referencing the defective Chinese tires. In a nutshell most trailer tire blowouts are not a result of ‘bad or inferior’ tires, they are a result of one or more of the following conditions.
Overloaded tires. Every tire manufactured has a load rating based on the tire’s inflation pressure. A tire’s maximum load is the most weight the tire is designed to support at the inflated pressure. ST tires have some of the highest load ratings. This is one of the reasons they are designated for use on trailers. Truck and automobile tires do not have to withstand the weight and stress that is put on trailer tires. The only way to know if a tire is overloaded is to weigh the trailer by individual wheel position. It is quite possible to weigh an axle and be within the axle weight rating, but when the tire positions on each axle end are weighed separately a tire rating can be overloaded.
Over & under-inflated tires. Another culprit for tire blowouts is over & under-inflated tires. Failure to maintain the correct tire pressure for the load can result in fast tread wear, uneven wear and poor handling which can all lead to tire failure. Remember, the load rating for a tire is only accurate if the tire is properly inflated for the load. Under-inflated tires cause extreme heat buildup that leads to tire failure. Tire manufacturers publish tire load and inflation tables with information on the correct tire inflation pressure for the load. A big reason tires fail is they are not properly inflated for the load. The appearance of the tire can look normal on the outside, but the internal damage is not visible. Tires with internal damage caused by under- inflation can fail catastrophically without warning. One thought is to inflate the tires to the maximum ‘cold’ pressure found on the tires sidewall if you don’t know the exact load on the tires, or the exact weight of the trailer. This should not however serve as an excuse to not weigh the trailer.
Improper weight distribution. When a manufacturer builds an RV weight distribution is critical. The weight from front- to-back and side-to-side must be carefully considered to avoid having too much tongue weight, too little tongue weight and/or too much weight placed on the trailer’s tires. The manufacturer did its job distributing the weight when the unit was built, now the RV owner must do their job by properly distributing any weight added to the trailer. Some tire overload conditions can be corrected by distributing the weight in the RV, but you still need to weigh the RV by individual wheel position to make sure there is not an overload condition.
ST Tire Speed Ratings:
All ST tires are rated for a maximum speed of 65mph. When you travel at speeds higher than a tire is rated for it will eventually fail. The heat that builds up in the tire results in fatigue and tire failure.
Here is some additional information taken from a Goodyear Tire & Rubber Company Product Service Bulletin, PSB #2011-13.
This bulletin provides important information to help your customers obtain the best performance from “Special Trailer” tires. Please review the following important points with your trailer tire customers. Special Trailer (“ST”) Tires: Goodyear Marathon trailer tires are widely used in a variety of towable trailer applications and are designed and branded as “ST” (Special Trailer) tires. Industry standards dictate that tires with the ST designation are speed rated at 65 MPH (104 km/h) under normal inflation and load conditions. Based on these industry standards, if tires with the ST designation are used at speeds between 66 and 75 mph (106 km/h and 121 km/h), it is necessary to increase the cold inflation pressure by 10 psi (69 kPa) above the recommended pressure for the rated maximum load.
Do not exceed the maximum pressure for the wheel.
If the maximum pressure for the wheel prohibits the increase of air pressure, then the maximum speed must be restricted to 65 mph (104 km/h).
About Fifth Wheel Group
