mich800
May 05, 2015Explorer
lynndiwagon wrote:
I just installed a RDS 60 gal. diesel aux tank in my PU. Seems to work OK and no leaks. When I took the cap off of the main tank, diesel came running out. My understanding of the system was that the float in the "T" would cut off flow from the aux. tank when the main tank was full up to the "T.". The "T" on the filler tube is about 1' below the main tank cap. Question, for those that use this system, is this the normal way things should work?
That is how it is supposed to work and the way mine works.
It does not overflow when the cap is removed. I believe my t is installed about the same as yours although a Ford.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
