Bird_Freak
May 11, 2015Explorer II
B.O. Plenty wrote:Works the same as the one I just installed also. No fuel runs out if cap removed.
Mine works just fine. You do have a check valve in the "T" that goes into your filler pipe. In order for that to work properly it must be mounted in a vertical position. I can remove the cap and never have a problem. If that is the case then it may be faulty. I would call RDS and ask them.
B.O.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
