nayther
Jan 19, 2016Explorer
PyroTekRob wrote:BigDogF250 wrote:
It's a low pressure propane quick disconnect hose, you can get them at most camping shops or Amazon. Keep in mind that it's already pressure regulated so you won't need another regulator between it and the grill.
Amazon 10ft.
Thanks again BigDog, you've been a huge help. Everyone has.
Ok got 2 more.
I got one of my propane tanks filled and tested my refrigerator today, clicked on got cold quick. But I noticed on the panel that both the Auto light and the Check light were on. What does the Check light mean?
And for the water heater, is there a way to turn it off? Or down so the water doesn't get hot?
not uncommon to get a check light when you change tanks or run it dry. The igniter will try to light the pilot a number of times and if it fails to sense a flame due to no gas (air in the line) it will show a trouble code (check light) and shut down. turn it off and back on on gas and it should light. Before doing that bleed the gas line at the stove.
About Fifth Wheel Group
