BigDogF250
Nov 22, 2016Explorer
Could be an o-ring, could be the hose from the valve to the tank, could be the valve on the tank. You can use soapy water to find it, it will bubble at the leak.
I have one that leaks at the valve while you are opening it but stops when it's close to fully open. Spare parts can be had from many sources, including Walmart, every RV parts store, every campground store and Amazon. I will replace the tank with the problem valve eventually, my local Costco sells them.
About Fifth Wheel Group
